CliveB
Aug 29, 2019Follower
D6400 firmware upgrades fails
Have tried upgrading to D6400-V1.0.0.88_1.0.88.chk via the router and via my mac from a dowloaded file. It seems to download but the little blue picture keeps on turning and it never finishes. Works ...
- Aug 29, 2019
> [...] via the router and via my mac from a dowloaded file. [...]
That tells me nothing. What, exactly, did you do?
> [...] D6400-V1.0.0.88_1.0.88.chk [...]
Presumably, if you got that file, then you also got the Release Notes
file, which points to the D6400 User Manual. Look for "Manually Upload
New Firmware and Update the Modem Router"?
antinode
Aug 29, 2019Guru
