Mike744
Jul 21, 2019Aspirant
D6400 Lan Setup - address reservation
After using the address reservation for renameing most of the hard to figure out names that are sent out by devices especially android devices and using fixed IP addresses, I noticed in the attached ...
- Jul 22, 2019
Mike744 wrote:
I also had to update each one by one from version 74.
Something wrong there. You should be able to jump all the way to the latest. The D6400 has never had a major change that requires an intermediate update.
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
This is a nuisance because you then have to reconfigure the device all over again.
You can backup your settings before you reset and restore them later. But that may just bring back the fault. Then again, at least you will know if the reset fixed the problem.
There is also a more drastic, "recovery reset":- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
The factory reset is more a "witchcraft" move than a technically informed solution, but it does seem to fix problems, especially on the wifi front.
michaelkenward
Jul 22, 2019Guru - Experienced User
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
Mike744
Jul 22, 2019Aspirant
I installed firmware version 88 manually as the automatic update kept showing "error:-1". I also had to update each one by one from version 74. I found them on the Netgear website under D6400. Each update was confirmed by displaying the correct version and I powered down and back one before loading the next version.
- michaelkenwardJul 22, 2019Guru - Experienced User
The factory reset is more a "witchcraft" move than a technically informed solution, but it does seem to fix problems, especially on the wifi front.- Mike744Jul 22, 2019Aspirant
I never thought of resetting the router between firware updates since it was new out of the box. I am going out of town for a few weeks so I will give it a try when I come back and have a day to spend reconfiguring everything. Thanks
