tarzan074
Nov 16, 2020Follower
d6400 sra setting
According to my isp their diagnostics say my sra setting in not enabled on my d6400, however as far as i can see the sra is enabled by default (page 287 of manaual) and cannot be disabled in user interface. What is my isp talking about and how can i prove to my isp this setting is enabled by default and i have not changed it? I have asked my isp to show me what proof they have that this setting is not enabled, no response so far, what should i do?
1 Reply
Apart from an odd setting, what problem do you have that you are trying to fix?
Why is this sra setting important to you?
Something running slow? Can't connect? Something else?
You have posted your message in the section of this community given over to General WiFi Routers (Non-Nighthawk). (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
DSL Modems & Routers
