MCrippa
Apr 29, 2020Tutor
Daisy chain gs108 and 1Gbps not working
Hi all, thank you in advance for your help. I've have two GS108ProSafe switches and I connected them in "daisy chain". The connection between the two of them is working at 100Mbps connection (just t...
- May 01, 2020
Glad to hear its not the switches. Sorry to hear its something within the wiring as its tends to be a pain troubleshooting.
If you mark it as solved, it might help the next person with issues.
Apr 29, 2020Guru - Experienced User
Simple check?
unhook the 1 device from where its at and directly connect it to the other switch with a short (known good) cable.
They're unmanaged switches so its an easy check.
Also, try different ports in case one's dirty/bad.
