MCrippa
Apr 29, 2020Tutor
Daisy chain gs108 and 1Gbps not working
Hi all, thank you in advance for your help. I've have two GS108ProSafe switches and I connected them in "daisy chain". The connection between the two of them is working at 100Mbps connection (just t...
- May 01, 2020
Glad to hear its not the switches. Sorry to hear its something within the wiring as its tends to be a pain troubleshooting.
If you mark it as solved, it might help the next person with issues.
Apr 29, 2020Guru - Experienced User
Simple check?
unhook the 1 device from where its at and directly connect it to the other switch with a short (known good) cable.
They're unmanaged switches so its an easy check.
Also, try different ports in case one's dirty/bad.
MCrippa
Apr 29, 2020Tutor
Thanks s lot fo your reply.
Connecting a pc straight to a port of the first switch, I get a 1Gbps signal (both led on) no matter which port I use. Same behavior connecting a pc to a port of the second switch (which is brand new). If I connect the two switches together, I get 100Mbps. Just one led is on on the port I use on switch 1 and on the port I use on switch 2 ( no matter the port I use). The connection is done using a short known good cable from switch 1 to the wall (Rj45 plug) then 25meters of cat6 cable and then another short known good cable from the wall to switch 2. The total distance (sum of cables lenght) is around 30 meters. I personally don't see this ad an issue but I might he wrong. I didn't test yet what happens if I put the 2 switches close to each other and I connect then via a single short known good Cable. I let you know asap.
