MCrippa
Apr 29, 2020Tutor
Daisy chain gs108 and 1Gbps not working
Hi all, thank you in advance for your help. I've have two GS108ProSafe switches and I connected them in "daisy chain". The connection between the two of them is working at 100Mbps connection (just t...
- May 01, 2020
Glad to hear its not the switches. Sorry to hear its something within the wiring as its tends to be a pain troubleshooting.
If you mark it as solved, it might help the next person with issues.
MCrippa
Apr 30, 2020Tutor
Test done. If I connect the two switches directly with a known good cable, they work at 1Gbps (both leds are on the ports I use). I did a bit of additional trouble shooting: the problem is either the cable in the wall or the connections (rj45 in the wall). I will redo the connections and we'll see. The switches are perfectly fine and I guess we can close this discussion. Thanks a lot.
May 01, 2020Guru - Experienced User
