thescinema's avatar
Mar 16, 2021
Daylight Savngs Time, NTP, DNS Issues
Something is going on with Orbi routers and NTP/DNS.
Since the time change, many users are reporting issues with their DNS failing since the time change:
https://www.reddit.com/r/orbi/comments/m5l3vk/orbi_dropping_dns/
Having same exact issue. It HAS to be related to the DST change, since DNS was working perfectly well for (I presume) all of us prior to the DST change.
I took advice of folks in the above thread and on the RBR50 I set NTP manually to the closest nist.gov server, toggled DST on/off, and lastly set DNS servers manually. Now I pray the issues do not resurface. I work at home, like so many folks do nowadays, so this will be a major productivity killer if I need to fart around with my home router several times a day.
If it doesn't provide a permanent fix, I am REALLY not looking forward to setting DNS manually on all my client devices.
It seems like this is a recurring issue with Netgear/Orbi. They need to get on this, now.
  • I am having a similar, maybe the same issue. You didn't mention in your post if your devices that are connected to the router via ethernet cable are experiencing the same issue as well. Currently all my wired devices are connected and working properly but any wifi device is showing "no internet" connection.
    I have my DNS servers hardcoded in the configuration to 8.8.8.8 and 8.8.4.4
    If I reboot the router it seems to work, but at sometime overnight (maybe after midnight) the problem reappears and wifi devices lose internet connectivity. One device alerts to a DNS issue, but again I have my DNS servers hardcoded in the router config.
    Netgear needs to address this issue and quickly.
    • thescinema's avatar
      thescinema
      Guide
      This is for all devices, whether wired or wireless. I first noticed it on my phone, and spent hours trying to figure out what could be wrong with my phone. Turns out, nothing, because it's happening with other devices here, too.
