ZanK
Apr 10, 2019Aspirant
Deactivation of the wifi
 when I activate the function 'Turn off wireless signal by schedule' the router deactivate just the broadcast of the SSID or completely deactivate the wireless signal from the router?
- Apr 10, 2019
It should completely deactivate the wireless signal and not just the SSID
ZanK
So there should not be any wireless interferences right?
Apr 10, 2019Guru - Experienced User
From that specific device. There might be others in your area broadcasting. I feel like I'm being led on......
- antinodeApr 10, 2019Guru
I don't know what that means to you.
It might be helpful if you described that actual problem which you
are trying to solve, rather than dancing around it this way.- ZanKApr 10, 2019Aspirant
I have a particular configuration that alternate 2 routers in determinated situations
