tantony
Oct 15, 2018Luminary
Default gateway on WiFi router
If I go to LAN Setup, I can configure static IP for this WiFi router, but how do I add the default router? The IP Address is 172.16.128.. IP Subnet Mask is 255.255.192.0, but I don't see a Default ...
- Oct 15, 2018
I don't have the bigger, global picture. For a router operating in router mode, the router is the default gateway. For routers operating in WLAN AP mode only, features like the DHCP server won't be available - but of course the management interface is able to take a single static default gateway address.
schumaku
Oct 15, 2018Guru - Experienced User
Well, these routers are designed and implemented for dead simple usage, the router itself is the default gateway, anything beyond of 255.255.255.0 can't be configured on the DHCP server, ...
tantony
Are there Netgear WiFi routers where I can put in the default gateway and DHCP? Or is this the same for ALL WiFi routers?
- schumakuOct 15, 2018Guru - Experienced User
