rverma28
Aug 08, 2016Aspirant
Default login and password don't work
Hi, I forgot my wifi password which I am trying to reset now. But I am unable to login on http://routerlogin.net using default login and password which is admin and password. Any advice? Thanks!
- AnonymousAug 10, 2016
push reset until power led flashes....use defaults on router label
http://www.downloads.netgear.com/files/GDC/WGR614V6/wgr614v6_ref_man_20Apr05.pdf
Read 7 -7
Anonymous
Aug 10, 2016push reset until power led flashes....use defaults on router label
Read 7 -7
- rverma28Aug 11, 2016Aspirant
Thanks! Problem is resolved now.
- AnonymousAug 11, 2016
You're Welcome!
I posted another discussion - https://community.netgear.com/t5/General-WiFi-Routers/Poor-Wifi-Coverage/m-p/1125547
Would you be able to help me out with this one as well?
