Tanis143
Nov 12, 2016Aspirant
delayed wireless access
Ok, this is a weird issue, not something I've seen before. All my wireless devices (three android phones [one S5 and two S7s] and a Tab4 tablet) show this same issue. It will show a wireless connecti...
- Dec 02, 2016
I just said screw it and bought a new router. Got the Netgear R6300v2. Since I work for my ISP I got it at a good discount. The difference has been incredible. My wireless speeds are no different than my wired speeds in all areas of my house.
Tanis143
Nov 13, 2016Aspirant
This happens on both 2.4 ghz and 5 ghz networks.
Retired_Member
Nov 14, 2016Try another FW version, did this just start happening? If new router return it or contact support.
- Tanis143Nov 17, 2016Aspirant
I might try another firmware if its available. And it didn't just happen, it was a gradual thing. At first it was just slow wifi access that would then speed up. Now its everytime you try to access anything internet it pauses for up to a minute, then goes through. Even going page to page it does this. And no, its not new. Trying to see if I can fix this or if its just time to upgrade.
- ElaineMNov 18, 2016NETGEAR Employee Retired
Tanis143 You may want to check as well the article below. The article is also applicable on 5GHz.
- Tanis143Dec 02, 2016Aspirant
