Recruiter
Sep 06, 2021Aspirant
Dell Inspiron 15 5000 Series laptop will not connect to Orbi
My Dell laptop Inspiron 15 series can see the Orbi as a viable network but my laptop just will not connect. I've already unplugged and turned onoff my Xfinity moden and Netgear modem. The laptop can ...
Recruiter
Sep 14, 2021Aspirant
Hello there,
I have an Inspiron 5559 Desktop -09FVSAF. I did not add any additional hardward to this Dell Laptop it came with everything I need. The Dell laptop used to connect fine a few years ago to Orbi and now it does not at all. It can see the Orbi device but it cannot connect. It shows up as a network to connect but the error I get is:" cannot connect to this network"
Here is a copy of my hardware I have:
Description: Realtek PCIe FE Family Controller
Physical address (MAC): f8:ca:b8:13:bd:e5
Status: Not operational
Maximum transmission unit: 1500
IPv4 address: 169.254.61.180/16
IPv6 address: fe80::b026:482d:1007:3db4%7/64
DNS servers: 75.75.75.75, 75.75.76.76
Connectivity (IPv4/IPv6): Disconnected
Name: Local Area Connection* 13
Description: Microsoft Wi-Fi Direct Virtual Adapter #3
Physical address (MAC): 7a:0c:b8:87:ac:2c
IPv4 address: 169.254.178.175/16
IPv6 address: fe80::b14f:2d0e:3019:b2af%17/64
DNS servers: fec0:0:0:ffff::1%1, fec0:0:0:ffff::2%1, fec0:0:0:ffff::3%1
Name: Local Area Connection* 4
Description: Microsoft Wi-Fi Direct Virtual Adapter #5
Physical address (MAC): 78:0c:b8:87:ac:2c
IPv4 address: 169.254.100.128/16
IPv6 address: fe80::1cde:a510:6b10:6480%5/64
Name: Local Area Connection* 14
Description: Microsoft Hosted Network Virtual Adapter
Physical address (MAC): 7a:0c:b8:87:ac:2b
IPv4 address: 169.254.198.179/16
IPv6 address: fe80::5dcb:c211:3900:c6b3%20/64
Description: Intel(R) Dual Band Wireless-AC 3160
Physical address (MAC): 78:0c:b8:87:ac:2b
Status: Operational
Link speed (Receive/Transmit): 97/97 (Mbps)
DHCP enabled: Yes
DHCP servers: 10.0.0.1
DHCP lease obtained: Tuesday, September 14, 2021 1:17:44 PM
DHCP lease expires: Thursday, September 16, 2021 1:17:44 PM
IPv4 address: 10.0.0.57/24
IPv6 address: 2601:644:8f80:5cd0::5735/128, 2601:644:8f80:5cd0:98e0:2858:7f51:c3bc/64, 2601:644:8f80:5cd0:58b6:db58:d5ec:90b4/128, fe80::98e0:2858:7f51:c3bc%11/64
Default gateway: fe80::deeb:69ff:fe5f:2731%11, 10.0.0.1
DNS servers: 2001:558:feed::1, 2001:558:feed::2, 75.75.75.75, 75.75.76.76
DNS domain name: hsd1.ca.comcast.net
DNS connection suffix: hsd1.ca.comcast.net
Network name: Geisha Girl 5Ghz 2
Network category: Private
Connectivity (IPv4/IPv6): Connected to Internet
michaelkenward
Sep 16, 2021Guru - Experienced User
Not much of that is specific to the PC.
We don't even know what Netgear equipment you own. "Orbi" is a brand name, not a particular device. There are dozens of Orbis out there.
How is the PC connected to the network? Wifi or Ethernet?
I can't tell from your first message.
It would also help if you answered some of the questions from plemans.
For example, you say:
"The laptop can see it but will not connect."
How are you trying to connect? What happens when you try to connect?
Does Windows show any helpful messages?
Try running the Network Troubleshooter in Windows.
Start here:
Fix network connection issues in Windows 10
Then there is this bit:
How many modems do you have in there? What are they? If any of them is a router, then you may well be into "double NAT" country.
What is Double NAT? | Answer | NETGEAR Support
and
How to fix issues with Double NAT | Answer | NETGEAR Support
