FullGrownNut's avatar
FullGrownNut
Denying Access to Specific Devices
I have a neighbor downstairs who uses my wifi signal for her devices, but I want to deny access specifically to her smart tv since it's causing my data with Xfinity to go overlimit every so often.  ...
  • michaelkenward's avatar
    michaelkenward
    Dec 18, 2021
    If only "smart" devices were smart enough to provide useful clues on connectivity problems. Then she might be able to work it out. As it is they usually just say that they can't connect. But without knowing exactly the device she owns it isn't possible to predict what she will see.
    But if she relies on your wifi and her TV suddenly stops working, it wouldn't take a genius to put two and two together.
