MissMick
May 04, 2021Tutor
DESPERATE! NO WIFI because I Mistakenly changed routerlogin.net password and can't log in
Subject says it all. How do I get out of this vicious circle? I STUPIDLY changed the password and now don't have wifi because I can't log in. Can't even fix this by using my iphone hotspot. Previousl...
May 04, 2021Guru - Experienced User
Did you try recoverying the password using password recovery?
If that didn't work, you can always factory reset by pushing and holding reset for 7-15 seconds.
MissMick
May 04, 2021Tutor
UPDATE: after going around many times with router restart, etc., I finally was able to access wifi again and fix my problem.
