Dianamanwaring
Jan 07, 2016Aspirant
Desperately needs to recover N150 password
 I can't recover my netgear password.  I changed it recently and thought I wrote it down but can't find it.  I practically tore the house apart.  That little slip of paper is long gone.     My Android...
- Jan 07, 2016
Make sure you have your laptop directly connected to the NETGEAR router on one of its 4 ports.
Your modem should be connected to the port by itself.
Can you verify what is the IP address when you did the ipconfig?
Dianamanwaring
Please......somebody help me! Between the issues with my laptop and the router, I've been working on this over 24 hours with very little rest. I am ready to drop.......am very stressed out and need help asap! Routerlogin.net won't work. Routerlogin.com won't work. 192.168.1.1 won't work. 192.168.0.1 won't work either. Help me!
ElaineM
Jan 07, 2016NETGEAR Employee Retired
- DianamanwaringJan 07, 2016Aspirant
Perhaps I misunderstood the instructions you both gave me? I didn't understand that I had to use an extra ethernet cable to connect the laptop to the router while the router was connected to the modem.
Got it fixed now. Thanks! Now I'm going to get some much needed rest!
 - ElaineMJan 07, 2016NETGEAR Employee Retired
You're welcome.
Have a good rest!
