NOWUCY2
Jan 05, 2022Follower
Detail settings A6100 dual band
Device manager details for my A6100. Im not sure what the correct settings should be. Win 11 3.1usb port. It wont hold its connectivity. The device is the problem. Any advice on these setting?
- Mar 04, 2022
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
WiFi Adapters - NETGEAR Communities
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
KevinLiT
Jan 06, 2022NETGEAR Moderator
Hello NOWUCY2,
I understand that the A6100 is having issues connecting to your Windows 11 Computer. Select the link below to download and install the latest driver.
Software Version 1.0.0.36 (Supports Win10)
https://www.netgear.com/support/download/?model=A6100
Please update me on your progress on this issue!
Best,
Kevin
NicoleNB
Mar 03, 2022Initiate
Hi Kevin, I have a new computer that runs on Windows 11. I have downloaded Netgear's latest software version 1.0.0.36 which says it supports Windows 10. After installing 1.0.0.36, my computer is now connected to the internet via the A6100 adapter and so far it seems to be working fine.
Does the current software version 1.0.0.36 actually support Windows 11 and/or will Netgear be putting out a software version for the A6100 that dos this?
I look forward to hearing from you.
Nicole
- michaelkenwardMar 04, 2022Guru - Experienced User
Support | NETGEAR
