oceanisuk
Sep 25, 2016Aspirant
device can not see network
This is a follow up to a previous thread on this subject which has now been closed. I just wanted to add that I had considerable problems getting my android phone to connect to my Netgear router and...
- Sep 26, 2016The router and phone were both purchased in the UK. I had just returned from the USA where the phone worked perfectly on every wifi network. I only noticed when I got back to the UK that it wasn't picking up my netgear router although it was picking up every other network. The solution for me was to change the wireless channel on the router from the one that it was on (13)to 7.
oceanisuk
Sep 26, 2016Aspirant
Retired_Member
Sep 26, 2016I understand it seems the phone is using the US plan which 13 is not part of. I was just curious!
Thanks
