TxDoc's avatar
TxDoc
Device doesn't see Netgear 59_5GEXT
My moto z play sees the Netgear 59_5GEXT connection, and.the Netgear 59_2GEXT connection, but my ASUS zenpad 8 and 10 only see the
Netgear 59_2GEXT. Why would this be? The STRONGER signal is the 5GEXT.
THANK YOU FOR YOUR TIME AND HELP.
Dr Mark
  • Hi TxDoc,
    Please make sure that the ASUS Zenpad 9 and 10 support dual band WiFi (able to connect to 2.4GHZ and 5GHz). You may refer to the product user manual.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi TxDoc,
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi TxDoc,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
