kcjudd
Aug 11, 2021Aspirant
Devices and Printers - Genie Media
I am now getting multiple Genie Media Servers showing up in Devices and Printers. How do I stop them from showing up? Does anyone have any suggestions? Thank you, KC Judd
michaelkenward
Aug 17, 2021Guru - Experienced User
kcjudd wrote:
Under the Basic tab, USB Storage, Media Server:
The Media Server Name is ReadyDLNA. None of the boxes are checked, I.e. Enable Media Server and Enable iTunes Server, they are not checked.
The radio button, Content Scan, is checked.
If I disable the Media Server, "Content Scan" is also disabled.
Is there any other DLNA server on your network?
What about the Netgear genie. Is that installed?
kcjudd
Aug 17, 2021Aspirant
Solved: I somehow downloaded the Genie software. Uninstalled it, fixed everything.
