ctippitt
Jun 12, 2019Tutor
Devices Connected to Network but Will Not Display webpages, Stream, Etc.
After verifying that my modem was working and reseting both modem and router, all my devices say that they are connected. Upon trying to access a webpage or streming service I get error messages sayi...
- Jun 12, 2019
Solved by netgear support.
ctippitt
Jun 12, 2019Tutor
So you're saying the issue would lie in the device preferences? I was having the same issue on multiple iphones, a roku tv, a macbook, and a pc. I am not that well versed in the stuff but could all those devices have the same issue simultaneously?
ctippitt
Jun 12, 2019Tutor
- michaelkenwardJun 13, 2019Guru - Experienced User
That's good news.
For the benefit of other victims, can you share their solution?
Marking it as "Solved" can lure people into reading what is actually an inconclusive discussion.
- ctippittJun 13, 2019Tutor
My girlfriend was actually the one who phoned netgear and followed their directions. But from what she described it was just a simple reboot: unplug modem and router, wait, plug in modem, wait, plug in router... Which is supremely frustrating because I did that exact song and dance twice the night before. Perhaps I didnt wait long enough who knows. My lesson from this is just call support fat the beginning.
Excellent feedback. Much thanks.
This sounds like the usual reboot issue. It happens often. You are not the first victim.
After any big changes on your local network, be sure to restart your network in this sequence:
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it connect.
- Turn on computers and rest of network.
That comes from Netgear's techies. As you guessed, the timing is important.
