fionnabj
Jun 09, 2022Aspirant
Devices on netgear
How Do I Find Out How Many Device On My Netgear
Jun 09, 2022Guru - Experienced User
On Netgear what?
Product model would be more helpful.
Log into the products web page or use a supported mobile app to see what is connected.
fionnabj
Netgear44
- FURRYe38Jun 09, 2022Guru - Experienced User
That's not a product model. R, RAX#### are model numbers.
- fionnabjJun 09, 2022Aspirant
I Found The Problem Thanks
- michaelkenwardJun 10, 2022Guru - Experienced User
The problem was? And the fix was?
The answers could help people who turn up later with the same problem..
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Search the manual for Attached Devices.
