LisaAnne
Nov 16, 2021Aspirant
Devices won't connect to 5G after latest firmware update
5G not working after FW version 1.0.1.76 ANY HELP appreciated...thank you
Nov 16, 2021Guru - Experienced User
Has a factory reset and setup from scratch been performed since last update?
- LisaAnneNov 16, 2021Aspirant
Not yet, that was my next step.
- plemansNov 16, 2021Guru - Experienced User
How do you know its not working?
What is showing for the wifi led's? (color/blinking)
What device are you testing on?
- LisaAnneNov 17, 2021Aspirant
I have tried to connect via my Samsung Galaxy phone and my laptop - both attempt to connect 5G then disconnect and connect via 2.4G on my Cell phone is says the 5G connection is SLOW...I did not have this problem BEFORE the firmware update
