Wolfie138
Jan 23, 2021Aspirant
DGN2200 Replacement
Hi all. i have the DGN2200 and since it's getting a bit old i'm thinking of a replacement/upgrade ~ any suggestions? The cheaper the better! TIA
Wolfie138
Jan 24, 2021Aspirant
sorry, my fault i guess. should have stipulated in the original post that i didn't want useless replies from assholes who think they're the wittiest thing to grace the internet.
that cleared up, replies from anyone else would be appreciated. ta.
antinode
Jan 24, 2021Guru
> [...] the wittiest thing to grace the internet.
I think that I see what you mean. When the competition is someone
whose entire list of requirements is "newer than a DGN2200 (some version
or other)", _and_, apparently, expects specific advice, then, when it
comes to pure hilarity, such feeble attempts as mine to elicit some
useful information are bound to fall short.
I wish you luck in your future endeavors.
- Wolfie138Jan 24, 2021Aspirant
because there's a whole range of netgear stuff and i want suggestions about any of them. Sorry it's so hard for you to work out. Netgear must be real pleased to have you here to welcome customers looking for help and advice.
