papantonis
Jan 06, 2022Aspirant
DGN2200 router limits attached devices to 15
I am using the DGN2200 router for the last 15 years without any major problem. The problem I'm facing Recently, I bought several smart devices to build up a smart home and realized the the route...
- Jan 06, 2022
You might try a factory reset. If this doesn't help any then it maybe time to retire this older modem and find something anew, or bridge the modem do that the rouer and wifi portions are disabled, continue to use the modem and install a newer generation Wifi router or wifi MESH system.
Netgear has set up a community forum specifically for the DSL Modem products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/DSL-Modems-Routers/bd-p/home-dsl-modems-routers
Thank you.
