nictri's avatar
nictri
Tutor
Apr 04, 2018
Difference between model D6200 and R6200
Hi, you know this difference, thanks.
  •    One big difference is that a D6200 includes a DSL modem.  For more
    details, you might try looking at the documentation for the two devices.
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Fetch some.  Read.  Repeat.  Compare.
  • Hi, Tank you for the reply
    You are a very precius resource
    regards.
