nocturnal93
Jun 30, 2017Aspirant
Difficulties with NAT settings on WNR2000v5 N300 WiFi Router
Hey guys, kinda new here. Anyways I bought a Netgear N300 Router and it worked great for the first year I owned it. Then out of know where my PS4 started having issues with connecting with other play...
- Jul 01, 2017
Those are private addresses. This is pretty common with WISPs. You'll need to call them and ask about the possibility of getting a static, public IP address. With this, you can use your WNR2000v5 as a router and enable UPnP. A less likely path is see if your WISP supports UPnP.
nocturnal93
Jul 01, 2017Aspirant
All of the IP's are 192.168.x.x
TheEther
Jul 01, 2017Guru
- nocturnal93Jul 01, 2017Aspirant
Thank you, I will do that once the holdiday is over.
