ray102866's avatar
ray102866
Follower
Apr 03, 2021
disable dhcp on r6200
every time i turn off dhcp and apply itt updates settings but when done dhcp hasn't been disabled
1 Reply
  • > disable dhcp on r6200
       Why?  Firmware version?  Connected to what?
    > every time i turn off dhcp [...]
       ADVANCED > Setup > LAN Setup > Use Router as a DHCP Server ?
    > [...] but when done dhcp hasn't been disabled
       The box is checked again?
       Sounds like defective firmware.  I'd try a settings reset and manual
    reconfiguration, but I wouldn't expect much.  You might also try a
    different/older firmware version.
       Visit http://netgear.com/support , put in your model number, and look
    for Downloads.  (For older versions, under Firmware and Software
    Downloads, look for "View Previous Versions".)  Find the kit(s).
    Download the kit(s) you want.  Read the "Release Notes" file for
    instructions.  (In the User Manual, look for "firmware", and,
    especially, for a topic like "Manually Upload Firmware to the Router".)
    When that fails because of a deficient User Manual, try:
          https://kb.netgear.com/23960
