ichabod
Oct 07, 2021Aspirant
Disable Netgear cloud management on R6230
I bought a Netgear AC1200 WiFi Router (Model no. R6230) for use in my employer's lab, and I need to figure out how to prevent it from "phoning home" to Netgear. Whenever I login to the web interface,...
ichabod
Oct 13, 2021Aspirant
(Sorry
Michael, thank you for your suggestion. It looks like the Remote Management option documented in the user manual doesn't exist in firmware version v1.1.0.110_1.0.1, which seems to be the latest available. (Screen shot attached.)
Perhaps the router does not phone home, but the web page's JavaScript has the browser trying to reach assets on a Netgear server, and when it can, the web interface redirects the browser to the Netgear site, insisting on a login. The only way I can get to the web interface on the browser is if I disconnect the router's WAN interface. I am connecting to the router through its Wi-Fi. I can't think of any engineering reason to present a different set of menus to LAN users on Wi-Fi than on Ethernet.
ichabod
Network trace showing accesses to Netgear servers.
- michaelkenwardOct 13, 2021Guru - Experienced User
Which makes me none the wiser.
Maybe it is just checking for firmware updates.
