socalgail
Apr 04, 2017Tutor
Disable SSID Broadcast
I regret buying this device. This ridiculous community will not even let me post a question and keep sending me to Arlo, whatever that is. How do I turn off the SSID broadcast? How do I DISABLE the ...
- Apr 10, 2017
Below is the link on how to disable the SSID.
VE6CGX
Apr 04, 2017Master
You can disable SSID broadcast in the wireless set up section. If you think hiding SSID imroves security, simple answer is not much.
I don't hide my SSID on my router. Experts can snoop your SSID even if it is not broadcasted
