jrrisk
Jul 16, 2020Tutor
Disable wi-fi on C3700, but not ethernet ports
I have my internet coming through my C3700 router, but due to the size of my home needed to set up a mesh network with 3 extender access points. When I did that, I now have three networks - the 2.4g,...
- Jul 16, 2020
> [...] C3700 [...]
C3700 or C3700v2? Look for "Model" on the product label.
> [...] direct me to a resource, [...]
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual (at least). Read.
Look for a topic like "Control the Wireless Radios".
michaelkenward
Jul 19, 2020Guru - Experienced User
The recommended solution to this challenge is to use the C3700 as a modem only (bridged) device. (See the manual.) This bypasses the router bit and turns off the wifi.
Then use the Mesh system as the router and access points.
The alternative is to use the C3700 a router and to put the Mesh in to wireless access point (AP) mode.
But not knowing what your Mesh system is, that's just a guess.
I assume that you have a proper Mesh setup. Simply slapping together a set of access points.is not a genuine Mesh system.
- jrriskJul 20, 2020Tutor
michaelkenward wrote:The recommended solution to this challenge is to use the C3700 as a modem only (bridged) device. (See the manual.) This bypasses the router bit and turns off the wifi.
Yes. This is correct. However, the wi-fi is not automatically turned off in a bridged set up. That had to be done manually. I did not have the manual available to manually turn the wi-fi off. Antinode provided a link to the manual as well as the specific sections to look at. This resolved the issue.
michaelkenward wrote:I assume that you have a proper Mesh setup. Simply slapping together a set of access points.is not a genuine Mesh system.
I set the Mesh system up according to the manual that came with that system. The first access point is plugged into the Netgear C3700 with an ethernet cable. The other two access points are connected wirelessly to the first.
