TheFrelle
Jul 28, 2015Initiate
Disabled NAT by accident, now I'm stuck with activating my router every 10'th minute
Hello folks! I know this seriously sounds dumb, but I had problems with my NAT configuration, and wanted to see what would happen if I turned it off (what an idiot I was). I'm now stuck with being ab...
- Jul 28, 2015
I actually found the solution, with some help from one of my friends, who just happens to be a good person to know, if you've got problems of this kind. I connected my laptop, to my router, and went to 192.168.100.1 which turned out to be a temporary solution instead of the normal 192.168.0.1 which simply did not work. I then turned on NAT again, restarted my router, and everything worked just fine!
netwrks
Jul 28, 2015Master
So what do you think you should be connecting to? What is supposed to be your DHCP Server and on what router?
- TheFrelleJul 28, 2015Initiate
