TheFrelle's avatar
TheFrelle
Initiate
Jul 28, 2015
Disabled NAT by accident, now I'm stuck with activating my router every 10'th minute
Hello folks! I know this seriously sounds dumb, but I had problems with my NAT configuration, and wanted to see what would happen if I turned it off (what an idiot I was). I'm now stuck with being ab...
  • TheFrelle's avatar
    TheFrelle
    Jul 28, 2015
    I actually found the solution, with some help from one of my friends, who just happens to be a good person to know, if you've got problems of this kind. I connected my laptop, to my router, and went to 192.168.100.1 which turned out to be a temporary solution instead of the normal 192.168.0.1 which simply did not work. I then turned on NAT again, restarted my router, and everything worked just fine!
