medicdad73
Dec 27, 2017Aspirant
Disconnecting issues 6900v2
I have searched in here looking for a answer, it seems since I updated to the newest firmware, even the beta R6900v2-V1.2.0.14_1.0.1_beta, the router diconnects all the time if there is any inactivit...
- Dec 27, 2017
Hi medicdad73,
1. Please make sure you do a factory reset after updating the router's firmware.
2. Does it disconnect all your devices (wired and wireless)?
3. Have you tried reflashing the firmware?
Dexter
Community Team
DexterJB
Dec 27, 2017NETGEAR Moderator
Hi medicdad73,
Dexter
Community Team
- DexterJBJan 02, 2018NETGEAR Moderator
Hi medicdad73,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team- HaVoChRiSJan 09, 2018Aspirant
Hello, I'm experiencing same issues. I have done the factory reset and updated to the latest firmware as described above.
- medicdad73Jan 19, 2018Aspirant
Yes, no luck, had to put in old firmware. Had a update today and the samething happened, the router disconnects all devices and then locks up.
Still experiencing issues, did the reset nothing. Had another update today, same problems.
Had to reload older firmware
