captnlen2
Aug 19, 2021Aspirant
DM11PSP Connectivity
OK we have Century Link was slow but fine for 6 yearsat this location This morning the lost Internet ability for about 10 hours When we got it back our network was gone. We still had a 2...
captnlen2
Wow. OK I am 80 and you will have to bear with me.
Century Link is Internet supplier
Have Netgear Modem and router
I have accessed the routerset up and it has a network and password
but when I go to settings (Iphone and Ipad) it says Network not found and gives me the network -ext added which is what I set up the extender as.
Accepting that gives me partial Internet access. I get Gmail, a browser etc. on my desktop which is cable to my router but even there there are applications that don't load. I cloud and printer are tw0
apple products are just not functioning on wifi
I have a laptop on wifi and it is also not functioning even on the 2nd _ext network
I went to setup Router and it shows the Network but the devices cannot find it. I did this on the desktop.
If the router is setup with a Network why can't any device on settings find it ?
Why on the PC cabled to Router am I still ot fully connected.
Spent 2 hours with Century Link(Internet source) tech and got no where. were to call back and didn't
Apple says it is Netgear or Century Link problem and no help there .
Hope this helps
michaelkenward
Aug 20, 2021Guru - Experienced User
What are they? Model numbers might be useful.
The DM11PSP is an aged (2008) ADSL modem router. You also have another router?
You can feed these into the support pages and get the manuals and check the troubleshooting sections.
DM111PSPv1 | Product | Support | NETGEAR
Support | NETGEAR
Feed in your router's model number and check the documentation for your hardware.
Check the section in the manual
Troubleshoot With the LEDs.
Is that an extender as well as the modem and router? If so, what is it? Make and model?
Does that mean that some things connect to the wifi another don't? Or does nothing work on the wifi? Are all the wifi LEDs showing as they should? (Sometimes people, and cats, can turn off the wifi accidentally, without realising that there is an on/off switch on the top.)
It can help to tell the wifi clients (the apple stuff, for example) to forget that it has already connected to your wifi. (There'll be a setting to do that somewhere on the wifi client.) Then connect to it as if it was the first time.
This bit isn't clear to me.
What "network" is this? Wired? Wifi? Where do you see it?
