hjorslev
Jul 09, 2016Follower
DMZ and port forwarding at the same time
I am on the hunt for a new router. Unfortunately, the router provided by my new ISP doesn't support using port forward and DMZ at the same time. My old router a Linksys E4200 is supporting port forwa...
- Jul 11, 2016
Hi hjorslev,
Yes, you can perform DMZ to a single LAN IP within your network and do port forwarding simultaneously. You can check the device user manual linked below.
http://www.downloads.netgear.com/files/GDC/R6400/R6400_UM_07Aug2015.pdf
Dexter
Community Team
DexterJB
Jul 11, 2016NETGEAR Moderator
Hi hjorslev,
Dexter
Community Team
