uclafr
Dec 26, 2020Follower
DNG2200 as access point
Hi. I setup my DGN2200v4 as access point following the user manual: connected the Ethernet WAN port from LAN port on my main router. then Advanced > Advanced Setup > Wireless AP then Enable Access Po...
Dec 26, 2020Guru - Experienced User
Access point mode isn't a mesh mode.
And even the mesh extenders don't function as mesh if ran in access point mode.
Its a seperate network with just the primary router controlling dhcp/nat.
You still set the wireless settings.
