nerdburt
Mar 28, 2022Aspirant
DNS Cache Issues on R6220
We have been unsuccessful in getting an iPhone 11 working with WiFi with our R6220 WiFi router, with iOS 15.4. When surfing the Internet with the iPhone, it is clear that DNS is not working properly...
Mar 28, 2022Guru - Experienced User
what modem/gateway is the router connected to?
Do you have IPv6 enabled? (if not, try it)
on the iphone, have you disabled the random ip/random mac option?
Did you try a different dns provider like googles at 8.8.8.8 or 8.8.4.4
- nerdburtMar 28, 2022Aspirant
Yes, we tried different DNS providers to no avail, and IPv6. Our provider does not carry IPv6 yet in this part of Canada, but we turned it on anyway, and no change. Have not tried the MAC ramdomization, so will give it a whirl and report back.
- nerdburtApr 01, 2022Aspirant
We have done a few things,which seems to make the iPhone work a lot better.
1.) Turn 'private address mode' off, also known as MAC randomization.
2.) Eliminated the port-forwarding that was turned on, as part of troubleshooting VoIP issues. We had UDP port forwarding enabled for two ranges of ports, and deleted them both.
I have also noticed the performance of the router improves slightly with these changes. I am assuming that the MAC randomization was putting the router into a bad state. Will now monitor to see if this improvement stays. Thanks for the idea.
