Winancy
Aug 03, 2021Apprentice
DNS>PROBE_FINISHED_NXDOMAIN error since latest update
Model R6400, firmware v1.0.1.74_1.0.48, Windows 10, ethernet connection Since I updated the firmware, I have been getting DNS_PROBE_FINISHED_NXDOMAIN errors when I open up browsers and go to webpage...
Winancy
Aug 08, 2021Apprentice
"Rolling back to an older fw version with security flaws is not "solved". "
And it didn't work for me. Still getting the same error.
Another question and please don't laugh.. If I buy a new router, not Netgear, give it the same SSID and password, will all my currently connected devices automatically connect to the new router?
robjak
Aug 08, 2021Luminary
Roling back worked for me. Have you rebooted, or on your computer:
ipconfig /release
ipconfig /flushdns
ipconfig /renew
It should.
How many clients on you network. if you assign DNS manually, it will work. but if you have lot of clients then it sucks.
- WinancyAug 08, 2021Apprentice
" Have you rebooted, or on your computer:
ipconfig /release
ipconfig /flushdns
ipconfig /renew"
Thank you! Releasing and renewing seems to have made it better. For the most part, most webpages will load, but still getting the nxdomain error on some, but reloading will bring up the webpage.Annnnddddd.......after using the internet for 15 minutes, it's back to getting the nxdomain again on more websites.
"How many clients on you network. "
Clients? - robjakAug 08, 2021Luminary
Different computers using the router.
- WinancyAug 08, 2021Apprentice1 desktop ethernet
1 laptop wifi
1 iPad
2 phones
Numerous smart devices - robjakAug 08, 2021Luminary
How much work to change the DNS settings on each. Can you easily change the DNS on the smart devices?
- WinancyAug 08, 2021ApprenticeI have absolutely no idea. But I don't think it would be easy. Easy would be buying a new router.
