Winancy
Aug 03, 2021Apprentice
DNS>PROBE_FINISHED_NXDOMAIN error since latest update
Model R6400, firmware v1.0.1.74_1.0.48, Windows 10, ethernet connection Since I updated the firmware, I have been getting DNS_PROBE_FINISHED_NXDOMAIN errors when I open up browsers and go to webpage...
mab305
Aug 19, 2021Star
Has any solution to this issue been found? I downgraded, reset to factory settings and that didn't resolve the issue. Next step is to purchase a new router and confirm that fixes it which would definately isolate the issue to Netgear. But obviously not the route I would prefer to take. That said, the problem is very disrupptive and needs to be addressed. I guess I could leverage social medial to inquire with Netgear and it would give other Netgear customer an awareness of the issue.
SSP2020
Aug 19, 2021Guide
Hi,
Please see the solution I gave and try that. after that run the following command in CMD through admin Mode.
ipconfig /flushdns
ipconfig /registerdns
ipconfig /release
ipconfig /renew
netsh winsock reset
Restart the computer
- mab305Aug 19, 2021Star
Thank you for the solution you shared. Unfortionately, it didn't work for me. I really appreciate your help!!!
Netgear: Please step-up and help with this issue...
- robjakAug 19, 2021Luminary
Rolling back the firmware fixed the issue for me and most others posting about the FW DNS problem. Verify that you are on the older firmware.
After downgrading, state exactly what is happening?
you should run ipconfig /release before the flushdns.
ipconfig /release
ipconfig /flushdns
ipconfig /renew
MAB305 see above post from olympos1625
I have been contacted by NETGEAR support to help troubleshoot issue, but of of course they contacted me the day i leave for a 2 week vacation. Others should do as olympos1625 posted to try and help find the problem.
- WinancyAug 19, 2021ApprenticeI have a phone appointment with them tomorrow.
I rolled back to the previous firmware and it didn't help. Same issues. - WinancyAug 19, 2021ApprenticeI have run the ip release, then flush dns, then renew the ip, restart the computer. Doesn't help.
Winancy
Confirm you are using R6400 Firmware Version 1.0.1.72 . Did you change any DNS settings before rolling back?
- WinancyAug 19, 2021ApprenticeRolled back 1.0.1.74_1.0.1.48 to 1.0.1. 72_1.0.1.44.
Didnt make any changes. I don't remember if I tried flushing the DNS before or after I did that. - mab305Aug 19, 2021Star
I also rolled back to the prior firmware version, flushed dns and reset to factory setting. Didn't fix the issue which I'm getting on a pc and two laptops.
- WinancyAug 19, 2021ApprenticeMab305
It's a DNS issue, so anything you have connected to the router it will affect.
I don't get errors on my phone or iPad, but there is a delay or a failure to load on those too. - mab305Aug 20, 2021Star
Thank you all for your suggestions and sharing of information! I did downgrade to v1.0.1.72_1.0.45. I also ran through the dns flush in the order suggested. Unfortionately, that did not resolve the issue.
Netgear....HELP!
- WinancyAug 20, 2021Apprentice
ipconfig /flushdns
ipconfig /release
ipconfig /renew
netsh winsock reset
Restart the computerI just did this and it didn't correct the problem.
Interesting observation though....there is no longer a notice that there is a new firmware update.
And when I logged into my router, there was a saved password, which was a bit disconcerting.
My appointment with Netgear is coming up shortly.
Thank you for your update! I noticed the firmware notification is gone too AND when I manually did a firmware update check it came back with no new firmware update is available.
I downgraded again. Now two versions back to v1.0.1.70_1.0.44. I think I'm still experiencing the issue, but it doesn't seem to be as bad. That said, it's only been a few minutes so it may be wishful thinking.
Would appreciate it if you update on on your call - good luck!
Netgear.....Please help us!!!!!!
With everything I've tried, it appears to fix the issue....for about 10 minutes. And then it's back again. And it fluctuates during the day as well. Will be horrible for awhile, I'll come back a couple hours later and it's not bad at all, an hour later, I have to hit reload 5 times to get a webpage to come up.
I just hope I get someone I can understand for support. I have some hearing loss which makes it even worse to understand accents not familiar to me.
- WinancyAug 20, 2021ApprenticeUPDATE AFTER NETGEAR SUPPORT:
- Downloaded the 1.0.1.74 firmware update and installed
- Factory reset the router
- Installed the Nighthawk app
- Cleared the browser data (all time)
- Restarted the computer
- Unplugged the modem and router
- Waited 2 minutes
- Plugged in modem first and then router
- It was WORSE than it's been all along
- Changed the DNS provider from using the internet provider one to using Google. 8.8.8.8 primary and 8.8.4.4 secondary
- Still getting the occasional DNS error, but usually immediately flips to the webpage
- Support Tech had no more ideas, will call back tomorrow to see how it's working and maybe go on from there.
- I'm going to tell her that at this point, I'm waiting for another firmware update and if that's still not working, I'm buying a different router brand.
Winancy: Wow. I feel your pain. This router has been an excellent experience and I've never had issues with it. In fact I would have recommended it and Netgear, but this update has made our network so unstable. We get issues during monetary transactions and it impacts work from home. I'm afraid I'm not able to wait and will need to purchase a new router. Unless Netgear fixes this in the next day or so, I will be purchasing a different brand and advising others to do the same. I don't want to that, but at some point I have no choice.
Hope tomorrow is better for you. Please keep us posted! Thank you again!
- robjakAug 20, 2021Luminary
Winancy
Sorry that you did not get any real support. I would have told them to get fk as soon as they wanted me to install the stupid app.
Did they not think we have not tried everything they presented?
- WinancyAug 20, 2021ApprenticeI'm finding the worst part of this right now is that my documents aren't uploading to One Drive. I rely on that as my backup. But I may have to go back to Google Drive until this is sorted out.
Oh and since all these changes today, I'm having trouble with things loading on my phone. I may just have to turn off wifi.
But we shouldn't have to make compromises because Netgears updates have fouled up the router. Technically, they should replace the router! - WinancyAug 21, 2021Apprentice
SATURDAY UPDATE:
Got a callback from the Netgear Tech Support person
She didn't remember what we did yesterday, so when she gave me suggestions, I had to tell her we did that already.
Then, she told me that firewalls cause this problem and wanted me to turn off the firewall and virus protection on my computer. I refused. I told her that it's been working just fine since I got the computer, I keep it updated and I'm not going to turn it off just to see if it makes everything better. I then told her that I'm at the point where I'm going to see how it goes for awhile, maybe there will be another firmware update addressing this, and then if it's not resolved I'm buying a new router. Didn't tell her that it most likely will not be a Netgear router!
She said she could elevate this problem, but she'd have to get some settings and take some screen shots before she could do that. I was reluctant, but eventually said ok.
Then, she had me go to chrome://net-internals/#dns and clear host cache. The only thing this did was to change the error from the nxdomain one to a err_name_not_resolved. She then told me that this indicates the it's not the router, but the internet service provider unable to identify the address of a webpage. I reminded her that we changed DNS to Google yesterday and she gave me some convoluted explaination that it was still a problem with Spectrum.
Then she said she'll touch base with me again and see how things are going. No timeframe. And she didn't elevate the problem to a higher tier.
Pretty fed up at this point.
- robjakAug 22, 2021Luminary
Winancy
Sorry again. I was hoping for more from "level 2 support". I would have lost it.
There is another post for the same issues where someone saw the packet where 192.168.0.1 (router) had actually rejected the DNS request. This is where the problem is and where NETGEAR needs to look. Not on in cache or firewall.
THIS IS NOT A FIREWALL ISSUE NETGEAR PEOPLE. THIS IS NOT AN ISP ISSUE.
quote from user dvinell
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/7-29-21-Firmware-update-1-0-4-74/m-p/2125785
I ran a Wireshark Trace, and what I saw was a DNS request to 192.168.1.1 (the router) followed by a DNS response from the router: "Refused".
"10515 2021-08-18 17:21:47.901153 192.168.1.12 192.168.1.1 DNS 75 Standard query 0xf3db A www.topgear.com"
10516 2021-08-18 17:21:47.901535 192.168.1.1 192.168.1.12 DNS 75 Standard query response 0xf3db Refused A www.topgear.com"
It then repeats the DNS request, gets a positive response, and it works.
- WinancyAug 22, 2021ApprenticeMy woes will be over tomorrow when my new TP-Link router arrives. I hope!
I saved the TP-Link Archer AX6000 to my amazon wish list 2 weeks ago. Just in case.
- mab305Aug 22, 2021Star
NETGEAR: This really is beyond disappointing. I purchased a new router and the issue is resolved. Please fix your firmware! The hours spent on this and the disruption is not acceptable.
