Winancy
Aug 03, 2021Apprentice
DNS>PROBE_FINISHED_NXDOMAIN error since latest update
Model R6400, firmware v1.0.1.74_1.0.48, Windows 10, ethernet connection Since I updated the firmware, I have been getting DNS_PROBE_FINISHED_NXDOMAIN errors when I open up browsers and go to webpage...
mab305
Aug 20, 2021Star
Thank you for your update! I noticed the firmware notification is gone too AND when I manually did a firmware update check it came back with no new firmware update is available.
I downgraded again. Now two versions back to v1.0.1.70_1.0.44. I think I'm still experiencing the issue, but it doesn't seem to be as bad. That said, it's only been a few minutes so it may be wishful thinking.
Would appreciate it if you update on on your call - good luck!
Netgear.....Please help us!!!!!!
Winancy
Aug 20, 2021Apprentice
With everything I've tried, it appears to fix the issue....for about 10 minutes. And then it's back again. And it fluctuates during the day as well. Will be horrible for awhile, I'll come back a couple hours later and it's not bad at all, an hour later, I have to hit reload 5 times to get a webpage to come up.
I just hope I get someone I can understand for support. I have some hearing loss which makes it even worse to understand accents not familiar to me.
