Winancy
Aug 03, 2021Apprentice
DNS>PROBE_FINISHED_NXDOMAIN error since latest update
Model R6400, firmware v1.0.1.74_1.0.48, Windows 10, ethernet connection Since I updated the firmware, I have been getting DNS_PROBE_FINISHED_NXDOMAIN errors when I open up browsers and go to webpage...
mab305
Aug 20, 2021Star
Winancy: Wow. I feel your pain. This router has been an excellent experience and I've never had issues with it. In fact I would have recommended it and Netgear, but this update has made our network so unstable. We get issues during monetary transactions and it impacts work from home. I'm afraid I'm not able to wait and will need to purchase a new router. Unless Netgear fixes this in the next day or so, I will be purchasing a different brand and advising others to do the same. I don't want to that, but at some point I have no choice.
Hope tomorrow is better for you. Please keep us posted! Thank you again!
Winancy
Aug 21, 2021Apprentice
SATURDAY UPDATE:
Got a callback from the Netgear Tech Support person
She didn't remember what we did yesterday, so when she gave me suggestions, I had to tell her we did that already.
Then, she told me that firewalls cause this problem and wanted me to turn off the firewall and virus protection on my computer. I refused. I told her that it's been working just fine since I got the computer, I keep it updated and I'm not going to turn it off just to see if it makes everything better. I then told her that I'm at the point where I'm going to see how it goes for awhile, maybe there will be another firmware update addressing this, and then if it's not resolved I'm buying a new router. Didn't tell her that it most likely will not be a Netgear router!
She said she could elevate this problem, but she'd have to get some settings and take some screen shots before she could do that. I was reluctant, but eventually said ok.
Then, she had me go to chrome://net-internals/#dns and clear host cache. The only thing this did was to change the error from the nxdomain one to a err_name_not_resolved. She then told me that this indicates the it's not the router, but the internet service provider unable to identify the address of a webpage. I reminded her that we changed DNS to Google yesterday and she gave me some convoluted explaination that it was still a problem with Spectrum.
Then she said she'll touch base with me again and see how things are going. No timeframe. And she didn't elevate the problem to a higher tier.
Pretty fed up at this point.
- robjakAug 22, 2021Luminary
Winancy
Sorry again. I was hoping for more from "level 2 support". I would have lost it.
There is another post for the same issues where someone saw the packet where 192.168.0.1 (router) had actually rejected the DNS request. This is where the problem is and where NETGEAR needs to look. Not on in cache or firewall.
THIS IS NOT A FIREWALL ISSUE NETGEAR PEOPLE. THIS IS NOT AN ISP ISSUE.
quote from user dvinell
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/7-29-21-Firmware-update-1-0-4-74/m-p/2125785
I ran a Wireshark Trace, and what I saw was a DNS request to 192.168.1.1 (the router) followed by a DNS response from the router: "Refused".
"10515 2021-08-18 17:21:47.901153 192.168.1.12 192.168.1.1 DNS 75 Standard query 0xf3db A www.topgear.com"
10516 2021-08-18 17:21:47.901535 192.168.1.1 192.168.1.12 DNS 75 Standard query response 0xf3db Refused A www.topgear.com"
It then repeats the DNS request, gets a positive response, and it works.
- WinancyAug 22, 2021ApprenticeMy woes will be over tomorrow when my new TP-Link router arrives. I hope!
I saved the TP-Link Archer AX6000 to my amazon wish list 2 weeks ago. Just in case.
- mab305Aug 22, 2021Star
NETGEAR: This really is beyond disappointing. I purchased a new router and the issue is resolved. Please fix your firmware! The hours spent on this and the disruption is not acceptable.
mab305 wrote:NETGEAR: This really is beyond disappointing. I purchased a new router and the issue is resolved. Please fix your firmware! The hours spent on this and the disruption is not acceptable.
I'm guessing that it's not widespread....or people just don't update their firmware. They don't have to do anything unless enough people complain.
SUNDAY UPDATE:
Just going to throw this out there.
Our son came to visit and brought his laptop and connected to the wi-fi. He is not getting any error messages and webpages are loading without issue.
The desktop, which is ethernetted to the router, is still getting error messages randomly, but then immediately goes on to the webpage. Except for a random one here and there that I have to hit reload.
Could this have anything to do with being wired into the router instead of using the wifi?
Check your sons settings on his laptop. Most likely his adapter is set to not use the router for DNS. (set manaully)
if a windows laptop run ipconfig /all scroll to find Wireless LAN adapter Wi-Fi look for DNS What is the ip(s)? compare to the desktop.
Mine would show as 192.168.0.1 (router) . My issues are on wi-fi. I have not checked if my ethernet devices are affected.
robjak wrote:Check your sons settings on his laptop. Most likely his adpater is set to not use the router for DNS. (set manaully)
That's pretty technical for me!!! And he's not wanting me to interrupt his game right now. :-)
But I found something very interesting and I'm not sure if I can adequately explain it.
I clicked on the Internet Access icon in the tray. It had been saying "network 2" for as long as I can remember. Just for the heck of it, I turned on wifi and clicked on the router SSID and connected to the router. I tested all the webpages that have been giving me issues and they all came up without a hitch. I then turned off wifi and it said I was connected to ethernet, but now the Internet Access doesn't say "network 2" anymore, it is the SSID name for the router. And everything is working just fine. UPDATE: It worked fine for the usual 10minutes and then back to the NXDOMAIN error, both on Chrome and Edge.
do you still have the newer FW?
I was thinking this might happen.
- WinancyAug 22, 2021ApprenticeFW?
firmware version.
