Winancy
Aug 03, 2021Apprentice
DNS>PROBE_FINISHED_NXDOMAIN error since latest update
Model R6400, firmware v1.0.1.74_1.0.48, Windows 10, ethernet connection Since I updated the firmware, I have been getting DNS_PROBE_FINISHED_NXDOMAIN errors when I open up browsers and go to webpage...
robjak
Aug 22, 2021Luminary
Check your sons settings on his laptop. Most likely his adapter is set to not use the router for DNS. (set manaully)
if a windows laptop run ipconfig /all scroll to find Wireless LAN adapter Wi-Fi look for DNS What is the ip(s)? compare to the desktop.
Mine would show as 192.168.0.1 (router) . My issues are on wi-fi. I have not checked if my ethernet devices are affected.
Winancy
Aug 22, 2021Apprentice
robjak wrote:Check your sons settings on his laptop. Most likely his adpater is set to not use the router for DNS. (set manaully)
That's pretty technical for me!!! And he's not wanting me to interrupt his game right now. :-)
But I found something very interesting and I'm not sure if I can adequately explain it.
I clicked on the Internet Access icon in the tray. It had been saying "network 2" for as long as I can remember. Just for the heck of it, I turned on wifi and clicked on the router SSID and connected to the router. I tested all the webpages that have been giving me issues and they all came up without a hitch. I then turned off wifi and it said I was connected to ethernet, but now the Internet Access doesn't say "network 2" anymore, it is the SSID name for the router. And everything is working just fine. UPDATE: It worked fine for the usual 10minutes and then back to the NXDOMAIN error, both on Chrome and Edge.
- robjakAug 22, 2021Luminary
do you still have the newer FW?
I was thinking this might happen.
- WinancyAug 22, 2021ApprenticeFW?
firmware version.
