Winancy
Aug 03, 2021Apprentice
DNS>PROBE_FINISHED_NXDOMAIN error since latest update
Model R6400, firmware v1.0.1.74_1.0.48, Windows 10, ethernet connection Since I updated the firmware, I have been getting DNS_PROBE_FINISHED_NXDOMAIN errors when I open up browsers and go to webpage...
Winancy
Sep 20, 2021Apprentice
I didn't have patience to deal with this issue for over a month. I bought a new router. I probably should have kept the Netgear one but I was so disgusted, I threw it in the trash. It was 5 years old though, so it got plenty of use.
robjak
Sep 20, 2021Luminary
MKX,
DNS fixed FW has not yet been released. Hopefully in a few days.
- anthonyss89Sep 21, 2021Initiate
Wow, read through everything, and sad thing is I feel like i am going to have to buy a new router which means i am going to have to port forward everything and set up IP reservations again. This blows, I have had netgear for everything for about 20 years and this dns probe bs is starting to annoy me, has any have an update to this? I tried every troubleshoot in the pervious comments but still have not had any luck.
- rasty777Sep 21, 2021Guide
it works!
- robjakSep 21, 2021Luminary
Rasty,
I spent years running DD-WRT and got sick of how buggy it was. I did try tomato for a bit, but prefered DD-WRT interface at the time.
Issue now is that Tomato does not run on my R8300.
If I go away from NETGEAR for routing, i would probably move to OPNSense on dedicated hardware and make my 8300 an AP. Probably with be my geekout project after this hunting season.
Anthony,
Fixes should be out soon. Hopefully.
- anthonyss89Sep 23, 2021Initiate
Crossing fingers, i downgraded thought it fixed the problem and it kinda did but its still there once in a while. I already started looking in the dream machine routers
- hrabcakmOct 12, 2021Star
Hi, same Here. I have following three routers with exactly same issue, 3 differents ISPs.
R6400v1 FW 1.0.1.74 - Long term issue, present also in previous versions of Firmware.
R6400v2 FW 1.0.4.120 - Same issue, occurs in last 4 Firmware versions.
R8000 FW 1.0.4.76 - Same issue, occurs in last 2 Firmware versions.
Seem that recent fw updates broke most of Broadcom based routers.
I can't rely that Netgear will release fix soon, based on the my previous experiences. So downgrade is only option this time, but downgrade means that you are running on outdated firmware without fix for major security vulnerabilities.
SW support is the weakest part of Netgear brand.
This issue is mentioned in many threads of this forum across many devices.
m.
- WinancyOct 12, 2021ApprenticeDowngrading is not the only option.
I couldn't wait around for months for a firmware update that might fix it. I bought a new router. Not Netgear. Their support is atrocious. They read off a script and have very little knowledge on how a router actually works. And in the end, when they are at the end of the script and your router still doesn't work they tell you to contact your ISP because it's their problem.
