Winancy
Aug 03, 2021Apprentice
DNS>PROBE_FINISHED_NXDOMAIN error since latest update
Model R6400, firmware v1.0.1.74_1.0.48, Windows 10, ethernet connection Since I updated the firmware, I have been getting DNS_PROBE_FINISHED_NXDOMAIN errors when I open up browsers and go to webpage...
antinode
Aug 04, 2021Guru
> [...] Is it possible to use a prior firmware version that did work?
Visit http://netgear.com/support , put in your model number, and look
for Downloads. (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".) Find the kit(s).
Download the kit(s) you want. Read the "Release Notes" file for
instructions. (In the User Manual, look for "firmware", and,
especially, for a topic like "Manually Upload Firmware to the Router".)
When that fails because of a deficient User Manual, try:
phenry9999
Oct 03, 2021Tutor
Thank you for the info about getting previous versions. The link was there, I just never saw it :< until I read your message and explicitly did a FIND on the page. Thank you. I'm going to try, systematically the previous versions to find out which one works.
- mkxOct 03, 2021Tutor
Don't waste your time on that version.
- phenry9999Oct 03, 2021Tutor
I just tried 1.0.4.74 and things are....so far so good. Not sure if it'll have probelms in the coming hours\days, but I have the previous versions to try too if this one goes bust. Does anyone know which specific version the DNS_PROBE_FINISHED_NXDOMAIN started happening with?
- WinancyOct 03, 2021ApprenticeGood luck. When I rolled back to a previous version or did any of the other suggested "cures" it worked for 15 minutes and then back to the same DNS issues. I no longer own a Netgear router.
