Winancy
Aug 03, 2021Apprentice
DNS>PROBE_FINISHED_NXDOMAIN error since latest update
Model R6400, firmware v1.0.1.74_1.0.48, Windows 10, ethernet connection Since I updated the firmware, I have been getting DNS_PROBE_FINISHED_NXDOMAIN errors when I open up browsers and go to webpage...
frothy333
Oct 13, 2021Aspirant
I'm getting the same DNS behavior. I hate to roll back the firmware b/c they said the update was critical. But, short of going to get a new router, the roll back will be the only choice.
michaelkenward
Oct 13, 2021Guru - Experienced User
Where did you read that? Which router do you own?
The Release Notes for the new firmware on the R6700v3 (see above) say that the new firmware "Fixes security vulnerabilities".
It says nothing about "critical".
Netgear, like other IT houses, never reveals what security vulnerabilities it hopes to fix. If it told you that, then the nasty people out there will know which unfixed vulnerabilities they can attack.
The "security vulnerabilities" term can mean many things. Often it means that some academic buried in a cave somewhere has cooked up an arcane exploit that can sneak into network devices in strange circumstances. These security vulnerabilities may not have been seen in the real world.
The choice is yours. Put up with the DNS errors you get and feel comfortable that lightning will not strike you. Or, like many other users, roll back to the previous firmware and run the risk that you may be the first person on the planet to see this security instructions.
- hrabcakmOct 13, 2021Star
Are you kidding us ?
https://www.pcmag.com/news/thanks-to-disney-11-netgear-routers-need-to-be-patched-immediately
- michaelkenwardOct 13, 2021Guru - Experienced User
Looks like that has nothing to do with this discussion.
Next thing you will tell us is that your rely in Facebook and Twitter for your advice on Covid.
I have yet to see a flood of messages from people who have been hit with security issues after reverting to earlier firmware.
Had those "vulnerabilities" been serious, they would have been evident before the "fix" turned up.
- phenry9999Oct 13, 2021Tutor
It doesn't say (at least I didn't see it) that Cirlce has to be on? I have it off (I'm not paying more $ monthly no less, for an already expensive router for something that should be incluced IMHO). That post does say if you use Circle, and I assume have it turned on in the router.
I'm with you there. But the truly paranoid will even spend money on Armor, another of Netgear's subscription services.
