tccarnuel
Nov 23, 2020Tutor
Does 2.4ghz signal interfere with 5ghz performance?
I've got a CM1000 modem and using Google Mesh Wifi, and am trying to problem-solve some performance issues. Today, my wifi started cutting out (completely) every 10-15 minutes or so, and I'm trying t...
tccarnuel
Nov 24, 2020Tutor
This is very helpful - really appreciated. So, because our devices are using the 5ghz signal, and we aren't detecting any competing 5ghz signals from the house (only 2.4ghz), it sounds like interference isn't an issue, which is a helpful rule out.
wcalifas
Nov 24, 2020Prodigy
Just an FYI, 2.4 ghz gives you longer range just not higher speeds, 5ghz gives you faster speeds with shorter range.
