FinnB
Jun 02, 2018Aspirant
Does buying a modem affect the need of a Netgear nighthawk router
Hey, I’m buying a Netgear modem and I currently have a nighthawk router. The main reason I got into all this is because my home WiFi is under too much pressure from other devices so I can’t game wi...
- Jun 02, 2018
> I'm buying a Netgear modem and I currently have a nighthawk router.
Actual model numbers would be more helpful than ambiguous/vague
descriptions.
> [...] can I plug a lan cable from the modem into my PS4 without the
> router or is the router still a necessity.
Generally, you can connect at most one device direvtly to a modem,
either an actual client device or a NAT router. "other devices"
suggests that you wouldn't be satisfied with one client device.
antinode
Jun 02, 2018Guru
descriptions.
FinnB
Thank you that helps a lot. The reason I didn’t go into detail on what modem I was buying and what router is because I didn’t think it mattered for this question as I was just wondering whether or not you can plug a lan cable from a PS4 to a modem.
Thanks
Thanks
