opticomm
Jul 04, 2022Aspirant
Does my AC1750 / R6400v2 Router need to be replaced?
My router is a Netgear AC 1750 R6400v2 802.11ac Dual Band. My 5.0 Wifi generally runs better in our small (1500 sq ft) home, but every so often it reverts to 2.4, then a weaker signal which causes my...
Jul 04, 2022Guru
do you have your 2.4ghz and 5ghz band named the same?
If they're they same, change the ssid's on the 2 names.
Then delete the 2.4ghz from your phone/devices remembered devices so it doesn't switch to it.
