opticomm
Jul 04, 2022Aspirant
Does my AC1750 / R6400v2 Router need to be replaced?
My router is a Netgear AC 1750 R6400v2 802.11ac Dual Band. My 5.0 Wifi generally runs better in our small (1500 sq ft) home, but every so often it reverts to 2.4, then a weaker signal which causes my...
Jul 04, 2022Guru - Experienced User
What reverts back to 2.4Ghz?
IT's up to devices to pick and choose where they connect too.
opticomm
Jul 05, 2022Aspirant
It happens on almost any device I happen to be on but mostly on my iMac, my wife's Mac, and my HP printer, and all are within 8 feet of the router. My Smart thermostat, which works only on 2.4, just loses its connection every few days and usually when I reboot the router (pull the power plug for 30 seconds and replace) it will come back on. Every so often the TV will switch over to 2.4 and becomes useless.until I get it back to 5.0.
