Jhakala
Jan 05, 2022Aspirant
Does Netgear send out firmware updates that you download for older products?
Got an email for a firmware (modem) update, supposidly from Netgear. Before I try it, I am wondering if it is ligit or if I would be opening my computer to thieves.
Jan 05, 2022Guru - Experienced User
what device do you have ?
What firmware is currently on it?
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
- JhakalaJan 05, 2022Aspirant
I have an N600 Dual Band router
- plemansJan 05, 2022Guru - Experienced UserN600 is a speed, not a model. What model is it? And what firmware is on it?
- wcalifasJan 05, 2022Prodigy
Its probably not from netgear, if you want to update your router just go to netgear.com under the support section and write your model number to see what is the latest firmware for your router.
